3D model from ArcGIS Pro to CityEngine
1058
06-02-2022 10:58 AM
RinuJoseph
I am new to CityEngine and ArcGIS pro. I am trying to generate 3D vegetation models in ArcGIS Pro from LiDAR point cloud data. If I have the 3D models of trees in ArcGIS Pro how can I bring that to CityEngine? My goal is to have a 3D model of an area in .usd format which is compatible with Omniverse Platform.
Thanks in Advance
Andrew--Johnson
If you already have the tree model displaying in ArcGIS Pro then it sounds like the data is in a geodatabase. If that is the cause you can follow this tutorial for how to import a geodatabase feature class into CityEngine. Any other questions on CityEngine are probably best asked in the CityEngine community.
https://doc.arcgis.com/en/cityengine/latest/tutorials/tutorial-4-import-streets.htm#ESRI_SECTION1_AF...
thanks,
Andrew
