Standardise KML to Layer row ID field name
1192
08-16-2021 08:44 AM
Status: Implemented
DuncanHornby
MVP Notable Contributor
In ArcPro 2.8 you can use the KML to Layer tool to convert a KMZ file to a Featureclass. Whilst the tool runs well it creates an unconventional field name of OID for the ObjectID field.
My idea is to simply standardise the output of this tool and ensure that the ObjectID field is called ObjectID. Most users (including myself) would be expecting to see this naming convention when output is created by a geoprocessing tool.
If you are developing model/scripting logic and suddenly a tool creates an unconventional name this can unhinge ones workflow. It's the same unnecessary irritation that I see sometimes with open source data formats when they decide to call the geometry field "geom"; when convention, certainly in the world of ESRI, it has always been called "Shape"...
5 Comments
JonathanNeal
@DuncanHornby I checked around each tool could name the ObjectId something different depending on the datasource it is writing to.  Consider using the following code if you need to know the Field Name. https://pro.arcgis.com/en/pro-app/latest/arcpy/functions/table-properties.htm
arcpy.Describe(<data>).OIDFieldName
DuncanHornby
Hi @JonathanNeal , As I wrote my idea I was aware of the approach you are suggesting arcpy.Describe(<data>).OIDFieldName and indeed I understand that would be best coding practise to always query the OID and geometry field name as they can be named something different. But that can add a level of complexity, albeit small, to any code and more importantly these tools are used in modelbuilder; it's just right royal pain in the a$$ to have to deal with! All this can vanish if ESRI tweak their tool to write out the ObjectID name as ObjectID for a geodatabase featureclass instead of OID. This would allow code/model development to flow more easily, be simpler and less likely to fail if everyone on the ESRI platform is working to the same standard/naming convention.
GISnIT
Is there a way to keep the symbology and fields from the KML in the shape file?
DrewFlater
The OID field naming for the output of KML To Layer has been addressed in ArcGIS Pro 3.2. The feature classes should always have an OID field named OBJECTID.
MargaretCrawford
This Idea has been implemented in ArcGIS Pro 3.2. Please see the What's New documentation for more new features in Pro 3.2.
The Your Ideas in ArcGIS Pro 3.2 blog and video have been posted to the Esri Community blog. You can take a look at these to see your idea and all others that were implemented in this release of ArcGIS Pro.
