ArcGIS Pro 3.2; Mobile Geodatabase:
I've created a new map/project and a blank FC for testing purposes. The FC uses a projected coordinate system: NAD 1983 UTM Zone 17N.
The FC has been added to the map. When I try to create a feature, I get an error in the Create Features pane:
Failed to create main.A_TEST_FC.
The coorindates or measures are out of bounds.
Video:
I think the problem is that I'm drawing outside of the extents of the projection. If I add a different FC that already has features, use Zoom to Layer to zoom to the features, then I can create features successfully in my original FC using those extents. That works, but it seems clunky, and I still don't know the actual limits of the editable area.
Could ArcGIS Pro be enhanced so that it shows me the extents of the FC/projection? Such as display a rectangle in the map that delineates UTM 17N. Or add the projection as some sort of read-only reference layer to the map.
Projections aren't my area of expertise; I use UTM 17N exclusively and never think twice about it. So let me know if I've missed something. It might not even be the projection that's causing the issue; it could be some other mechanism that has limited extents.
Additionally, could the wording in the error message be improved?
That makes it sound like I failed to create a new feature class. But that's not the case; I failed to create a feature within an existing feature class.
