Set and honour timezones in Pro
380
07-14-2025 04:54 PM
Status: Implemented
RTPL_AU
Honored Contributor
I have set data with a Date/Time field to use our local time zone when published  from Pro to AGOL for use in Field Maps.
This timezone matches my computer when I view the data in a FGDB extracted from AGOL once a field job is completed.
Why on earth is the data in the FGDB showing in UTC when at no point in the chain had I used UTC?
(Rhetorical question - I know why, hence this Idea)
Please provide a way to work in local time or a set time zone in Pro (incl AGOL data shown in Pro) and have ALL data show in local time no matter what method used to interact with the data (popup, attribute table, ouji board).
Brownie points for clearly indicating when a displayed field is in UTC vs Local Time/a set timezone.
Having to constantly check times and dates against other sources of info to make sure the correct version is extracted is time consuming and inefficient. Nothing can be assumed as sometimes environmental observations are done at night or early in the morning so travel logs etc are needed to validate dates.
Just give us a button to set a timezone and then honour it everywhere.
2 Comments
NathanShephard
Thanks for submitting this Idea!
Good news - it is in our Product Plan for Pro and we're working to get this done in the next 1-2 releases. You will have the option to use the Map's time zone applied as the display time zone for all time-aware content in the map.  There are a lot of places where Time Zone display needs to be honored (eg: tables, labels, attribute editor pane, etc) so we need to look after all those.
Thanks!
-Nathan.
NathanShephard
Good news - we shipped this with ArcGIS Pro 3.6.
Quick overview:
  • Per usual, set time properties (inc. time zone) for individual layers in Layer Properties > Time
  • Then, either on the Time ribbon or in Map Properties > Time, set the map's time zone
  • Then, check on the option to "Display values in this time zone"
  • RESULT - all places where time-zone-aware content is shown (tables, attributes pane, time slider, etc), the values will be converted and shown in the map's time zone
  • The display time zone can be seen in places like the hover-tip-help for columns in the table, and explicitly stated when editing values using the Calendar control.
More detailed information is available here:
Hope this helps!
-Nathan.
