Currently ArcPro (version 3.0.2) allows you to show vertices by holding the T key, but it only shows the vertices in a square box that you have to hover over a line. This is incredibly clunky/annoying to use while editing.
In ArcMap, you can hold the V key, and all vertices show up, sometimes they remain shown even after releasing the V key, allowing you to easily (and quickly) create features that snap to existing vertices.
Idea: Modify the T key in ArcPro to show all vertices of a feature, and better yet, keep the vertices shown until you hit the T key again.
@ChristopherJStrong When an edit tool is active and you press the T key, a search of all snappable points (Point, Endpoint, Vertex, and Midpoint) within your defined snap tolerance (default is 10 pixels) occurs at the cursor location on the map with results displayed in a snap cache. You can limit the display cache results by disabling snap agents e.g., only enable vertex snap agent to show results of vertices on the line feature.
Snapping needs to be ON to display snap cache using the T key. One way you can show all vertices of a line is to increase the snap tolerance interactively or manually typing value in Editor Settings dialog so that the display snap cache covers the entire length of a given feature.
When snapping is OFF, hovering over a feature then pressing the T key highlights all vertices on that feature, similar to ArcMap behavior. I’d suggest trying if this works for you.
In addition to this, you can use marker symbol layer with marker placements at vertices along the line feature.
I hope this helps.
Although I prefer the ArcMap method, it is nice to know you can do this in Pro.
@JMutunga, what is the name of the tool in Pro that displays the snap cache? I would love to reassign the shortcut key to the letter v.
You can change the keyboard shortcut here:
FYI
F12 key also gets you to the Keyboard Shortcuts dialog.
Implemented in ArcGIS Pro 3.5
https://pro. arcgis.com/en/pro-app/latest/help/editing/symbolize-vertices-and-nodes.htm
Is this option available in Pro 3.7?
Vertices and Nodes was implemented at 3.5 and allows you to see all vertices, among other things like nodes, pseudonodes, dangles and more:
You can customize it to your liking on the settings page for it:
If you're asking about being able to use the T key to show vertices or the snapping cache while sketching - like I showed in my comment from 2 years ago above or customizing it to a different key, yes, you can still do this at 3.7.
