Provide a tool to highlight True Curve geometry in data
351
07-01-2025 07:55 PM
Status: Already Offered
RTPL_AU
Honored Contributor
Pro 3.5.1 and The June 2025 Update AGOL
Seeing as there is currently a disconnect between True Curve behaviour in Pro and Field Maps, please supply a tool to highlight True Curve geometry in data.
This has two aspects:
  1. Run the tool on data to show if True Curve geometry exists
  2. If it exists, highlight the affected area in each object in which it exists.
3 Comments
Scott_Harris
Hi @RTPL_AU This is possible at ArcGIS Pro 3.5 by turning on Curved Edges and/or Bezier Curved Edges within the Vertices and Nodes settings and enabling it in your map.
More info:
https://pro.arcgis.com/en/pro-app/latest/help/editing/symbolize-vertices-and-nodes.htm
https://pro.arcgis.com/en/pro-app/latest/help/editing/change-vertices-and-nodes-settings.htm
RTPL_AU
@Scott_Harris
Thank you.
Quick question - How far down the page should I go when searching for True Curve in the docs 🤣🤣🤣
I tried 'true' in the docs you referred to:
It also is not listed when you search for True /  True Curve in Pro's Command Search.
I'm not lodging another Idea to improve the search and/or documentation. That is a standing order that I hope someone at Esri is taking to hart.
Scott_Harris
Thanks for the details on searching in the documentation for this topic @RTPL_AU , I've notified the team.
