Pick symbology colors from a color palette
1132
10-25-2023 11:34 AM
Status: Open
AllenDailey1
Create a way to change a feature's color to another color from the selected color palette / color scheme when using Unique Values symbology.
I am working with a polygon feature class and using Unique Values to make each polygon visually distinct, like on classic political maps where each country is a different color.  I'm using the "pastel" color scheme. But in some cases, there are so many polygons adjacent to each other (very odd sizes and shapes) that some adjacent polygons are just about the same color.  I have to go through and manually change the color of some polygons to make the colors more distinct.  It is frustrating that I can only pick colors from the standard ArcGIS color picker, or else create custom colors via RGB, HSV, etc., and I cannot pick from the "pastel" color scheme I selected for the layer's symbology.  This is making the layer's symbology look pretty random and unprofessional.
It would be a giant help to be able to change a feature's color to another color from the color palette I chose for the layer.
2 Comments
MErikReedAugusta
Seconded!  Right now, this requires opening the Color Scheme list, clicking "Format color scheme", manually copying the Hex codes for each of those colors down somewhere, then on the actual symbol, opening the color selection for that symbol, clicking "Color Properties", and finally pasting in that Hex code.  One at a time.  Every time.
It's more than a little maddening.
And as a tangential aside, it's especially maddening when you're trying to do something relatively simple like 4-color or 5-color map theory on a feature of contiguous polygons, which is something that it still surprises me isn't already built into ArcGIS Pro as an option, and now you're having to do this mildly obnoxious process on top of it.
KoryKramer
Make sure to kudo this idea for 4-color theory since you mentioned it https://community.esri.com/t5/arcgis-pro-ideas/incorporate-the-4-color-tool-into-arcgis/idi-p/927482
