Open Story Maps from ArcGIS Pro
609
11-17-2023 01:39 PM
Status: Under Consideration
LyonMNGIS
Occasional Contributor III
Hello,
Please consider adding an ability to add a context sensitive menu to  "Open Story Map Website" or "Copy URL" from the ArcGIS Pro Catalog.
Thanks
3 Comments
KoryKramer
@LyonMNGIS it isn't in the context menu, but you asked for "Copy URL" from Catalog view which is already possible:
Copy Path copies the URL and you can paste that into a browser.
From the Catalog pane, with the pop-up enabled you can click the item's url and open the storymap from there:
LyonMNGIS
@KoryKramer
Thank you for pointing it that I can use "Copy Path."
Just my two cents...  I personally only use the "Catalog View" and not the "Catalog Pane."  The functionality in the Catalog Pane works exactly as I would otherwise want within the Catalog View.  Can that be ported over?
Thanks.
NaicongLi
