Maintain Values in Production Z Management Toolbar
1292
02-02-2017 08:13 AM
Status: Closed
ChrisSheridan
Add the ability to set a default Z value other than 0 in the Z Production Manager toolbar. My company frequently works on projects in which we edit data collected in 3D in a 2D environment. In order to ensure that any vertices that are modified or added to features during 2D editing, a default value that falls outside the possible realm of Z values is used on those vertices that were not collected in 3D using the Production Manager toolbar. The problem is that the value that is set is lost anytime that Arc crashes and it always reverts back to 0. It would be beneficial to be able to set the value in the Z Management section of the Production Properties so that values can be retained between different sessions of Arc.
2 Comments
JenniferCadkin
Status changed to: Closed
ArcGIS Desktop is in mature support  and will be retired March 1, 2026 so we won’t be considering this idea. We recommend that you migrate to ArcGIS Pro, our fully supported desktop GIS application. See Migrate from ArcMap  to ArcGIS Pro for more information. Thank you for taking the time to share your ideas.  We truly appreciate your contributions to continuously improving the software to help you do your work and look forward to what ideas you have for ArcGIS Pro.
ConstanzaRomero
 JenniferCadkin
Where can you use this toolbar from arcgis pro? i can not find them
