Improve 'Add Row' behavior of Abbreviation Dictionaries interface
1013
09-13-2022 11:46 AM
Status: Implemented
wayfaringrob
Honored Contributor
Adding new entries to an abbreviation dictionary is a little clunky at the moment. When clicking add row, the interface does not update to show the new row nor is it ready for you to start typing into it. After adding the row, you must manually scroll to the bottom, select it, and type your entry. It's also pretty difficult to navigate with a keyboard: instead of just tabbing past the last row or hitting enter to get a new row, I have to tab over to 'add row,' hit space, and then shift-tab back to the rows, where again, the new row is not selected -- the row above the new row is selected, so you then have to tab down again. Once again, that's tab, space, shift-tab, tab; and really, just 'tab' would be nice especially when you have a lot to enter at once. Would also be consistent with other applications and give users an intuitive experience.
2 Comments
WendyHarrison
thanks for bringing this to our attention.  we will work at improving the accessibility for this workflow
WendyHarrison
This is implemented in ArcGIS Pro 3.4. Go to Your Ideas in ArcGIS Pro 3.4 to see other ideas implemented this release and check out the What's New help to learn about everything that is new and improved in ArcGIS Pro 3.4.
