Generate polygon FC from folder of raster images
255
10-01-2024 01:22 PM
Status: Open
Bud
Esteemed Contributor
ArcGIS Pro 2.9.5
I have a folder containing ~500 Lidar DSM .IMG files that I downloaded from a GeoHub webpage.
Using a single geoprocessing tool, I want to select the folder and output an FC that has polygons for the extent of each image, with the image name as an attribute.
1 Comment
RichardHowe
I'm not sure there's a single out of the box tool that will do it. If you batch add them to a mosaic dataset you can then export the footprints though using the Copy Features tool.
A process you could script to build your own single click tool if it was a task you were going to have to repeat
