ArcGIS Pro's "GPX To Features" geoprocessing tool doesn't handle tracks correctly - it needs more options/settings so it converts each track in the GPX file to a line feature.
Currently, the tool has these parameters: Input GPX File, Output Feature Class, Output Type ("Points" or "Tracks as polylines"). It has no Environments settings.
The "Points" setting seems to work fine. The "Tracks as polylines" setting gives useless results, at least for the GPX file I tried to use it for. This file contains some waypoint <wpt> tags, but mostly consists of hundreds of track <trk> tags, each of which contains a <trkseg> tag that contains several <trkpt> lat/lon pairs. Each track (<trk>) represents a trail or section of a trail. Some of the tracks contain a <name> tag and some don't. Here's a small sample (I replaced most of the <trkpt>s with "(etc...)" to save space:
<trk>
<name>Berry Pond Road</name>
<trkseg>
<trkpt lat="42.61294" lon="-71.091489">
</trkpt>
<trkpt lat="42.612943" lon="-71.091457">
</trkpt>
(etc...)
</trkseg>
</trk>
<trk>
<trkseg>
<trkpt lat="42.61088939999998" lon="-71.0602296">
</trkpt>
<trkpt lat="42.6110512" lon="-71.0600043">
</trkpt>
(etc...)
</trkseg>
</trk>
<trk>
<trkseg>
<trkpt lat="42.62879410000001" lon="-71.0780068">
</trkpt>
<trkpt lat="42.6288179" lon="-71.0780753">
</trkpt>
(etc...)
</trkseg>
</trk>
<trk>
<name>Bay Circuit Trail</name>
<trkseg>
<trkpt lat="42.61758360000002" lon="-71.0909179">
</trkpt>
<trkpt lat="42.6177747" lon="-71.0910559">
</trkpt>
(etc...)
</trkseg>
</trk>
<trk>
<name>Healthy Heart Trail</name>
<trkseg>
<trkpt lat="42.62006399999998" lon="-71.084965">
</trkpt>
<trkpt lat="42.620004" lon="-71.085102">
</trkpt>
(etc...)
</trkseg>
</trk>
<trk>
<trkseg>
<trkpt lat="42.61796699999999" lon="-71.085417">
</trkpt>
<trkpt lat="42.618123" lon="-71.085506">
</trkpt>
(etc...)
</trkseg>
</trk>This sample contains:
The geoprocessing tool will handle the Berry Pond Road track and the Bay Circuit Trail track correctly (each becomes a line feature in the output File Geodatabase feature class). However, if there are two or more consecutive tracks with the same name (like Healthy Heart Trail) or no name, the consecutive tracks get combined into a single line feature, and it connects the last vertex of one track to the first vertex of the next track. Here is a screenshot of the result:
I'm not sure if the GPX file I was given is a typical GPX file or an oddball one, but it's hard for me to imagine a case where someone would want the result above.
Please fix this geoprocessing tool!
Either:
Here's a mockup of what it might look like 😁
Thanks!
@David_Kimball To get you working, consider looking at these 3 tools: Reconstruct tracks allows you to split on additional fields for time enabled data. I am hoping the (etc....) has those needed timestamps to get order. If not, maybe you can use Feature Vertices to points to split out the points, and Points to line to sort it by your name field.
1. Reconstruct Tracks (GeoAnalytics Desktop)—ArcGIS Pro | Documentation
2. Points To Line (Data Management)—ArcGIS Pro | Documentation
3. Feature Vertices To Points (Data Management)—ArcGIS Pro | Documentation
Thanks for your reply Jonathan. I looked into it, and it turns out the GPX file I was sent is just a dump of OpenStreetMap data from their JOSM editor (I wish I had known this before I wasted time trying to import it). The data doesn't contain any time information, and most of the tracks don't have a name, so I don't think any of your suggestions would work. But it looks like this is probably an atypical GPX file, so maybe my problems aren't relevant to normal GPX files. Still, it seems weird that the geoprocessing tool essentially ignores <trk> tags if they don't also have a unique/non-consecutive <name> tag.
