Field Calculator — Get attribute of touching feature from different FC
342
10-28-2025 01:43 PM
Status: Open
Bud
Esteemed Contributor
I have a POINTS FC and a POLYGONS FC.
In POINTS, I want to use the field calculator to populate a POINTS.ASSET_ID field with the ASSET_IDs from POLYGONS, where a point touches a polygon. The spatial relationship is 1:1.
In other words, I want to get the ASSET_ID from the intersecting polygon and use it to populate the ASSET_ID field in the point.
I want to do this all within a simple field calculation, not using multiple GP tools and joins.
I would also like this to work for cases where the ID fields don’t have the same name.
3 Comments
CraigWilliams
You can do this with Arcade in Calculate Field. Given the names you have above and with the Field Name of the calculate field tool being ASSET_ID on the Points layer:
var polygons = FeatureSetByName($datastore, "POLYGONS",['ASSET_ID'], true);
var polygonFeature = First(Intersects(polygons, $feature));
if (!IsEmpty(polygonFeature))
  return DefaultValue(polygonFeature, 'ASSET_ID', "9999");
else {
  return "9999";
SSWoodward
You could also implement this as an attribute rule on the point class using the Generate Spatial Join Attribute Rule GP tool, this way, if your point were ever to move, the ID field would update automatically to reflect the new polygon intersection.  Ensuring the rule triggers on updates to the shape field only will keep the rule from firing unnecessarily.
PandiyanKesavan
Try this arcade Code to solve
// Get the polygon feature class
var polys = FeatureSetByName(
    $datastore,
    "POLYGONS",          // <-- polygon FC name
    ["ASSET_ID"],        // <-- polygon field to pull from
    true
// Find polygons intersecting the current point
var match = Intersects(polys, $geometry);
// Since relationship is 1:1, get the first polygon
var poly = First(match);
// Populate point ASSET_ID
return IIf(IsEmpty(poly), null, poly.ASSET_ID);
