Add functionality that tells you how far a particular point moved between versions, instead of just telling you that it moved beyond the tolerance you specified.
At this time we do not have a plan to offer this enhancement to Feature Compare. You can run Near as a post process to determine the distance between points. The order of comparison for Feature Compare can be set using the parameter Sort Field.
Sign in to post, follow content, and more. New here? Register for free.
