Enable Full GeoParquet Support in ArcGIS Pro, AGOL, and Enterprise with Databricks Integration and Pre-rendered Publishing
546
7
11-21-2025 05:01 AM
Status: Needs Clarification
MariusBartašius
1. Direct GeoParquet Publishing
  • Allow publishing GeoParquet datasets as hosted feature layers or vector tile layers in AGOL and ArcGIS Enterprise.
  • Support pre-rendered vector tiles for large datasets (e.g., millions of parcels) to optimize performance and reduce client-side load.
2. Databricks Integration
  • Enable ArcGIS Pro and Enterprise to connect to Databricks Unity Catalog and read Delta tables with spatial columns (WKB/WKT).
  • Provide native connectors for secure, governed access to spatial data in Delta Lake.
  • Support Arrow streaming from Databricks for zero-copy data transfer.
3. Apache Arrow Integration
  • Use Apache Arrow as the in-memory representation for GeoParquet and Delta tables.
  • Expose Arrow-based APIs for ArcPy and geoprocessing tools to enable high-performance analytics.
4. Performance Enhancements
  • Implement server-side pre-rendering for large datasets before publishing (similar to tile caching).
  • Support scale-dependent rendering and progressive loading for big data visualization.
  • Optimize workflows for thousands of users and multi-million feature datasets.
7 Comments
VenkataKondepati
Apache Sedona support as well
DanPatterson
GeoParquet support in ArcGIS Pro - Esri Community  a related idea exists as well
MariusBartašius
@DanPatterson ,
GeoParquet is supported. We want full support with web publishing, also delta tables integration.
Related idea is finalized already - https://www.esri.com/arcgis-blog/products/arcgis-pro/announcements/geoparquet-arcgis
JonahLay
Hi @MariusBartašius ,
Are you aware that you can share data from Apache Parquet files starting at ArcGIS Pro 3.6? The following web layers that copy all data to ArcGIS Online or ArcGIS Enterprise 12.0 and later are supported:
  • Web feature layer
  • Vector tile layer with an associated web feature layer
  • Web scene layer with an associated web feature layer
  • Hosted table
MariusBartašius
Thanks, I didn't know. But yet, partly answers my question, is it possible directly publish from delta tables from databricks?
I need that too.
JonahLay
@MariusBartašius Not currently from ArcGIS Pro. There might be a workflow to handle Databricks with ArcGIS Data Pipelines. See this help topic: https://doc.arcgis.com/en/data-pipelines/latest/connect/input-databricks.htm
nitinchauhan2
We are able to connect to Azure Databricks via Simba Spark ODBC driver in ArcGIS Pro. However we have seen that Pro is able to fetch few Delta tables correctly while for some its throws error and is unable to open the tables.
However, this is just a way around as standard connector for same is not available.
