I am a GIS Analyst and variously map coastal areas to inform visitors to both terrestrial parks and neighboring marine reserves. Tourists tend to understand kilometers, whereas serious boaties know nautical miles.
I am delighted dual scale bars was added at v3.5 (thanks heaps!). This saves a lot of "finessing" time.
May I ask for an additional refinement in future? Could nautical miles be added as a drop-down option please?
Thank you very much for your consideration.
This has appeared before regarding project units, but obviously not closed/implemented
Add nautical miles as a default to project Units >... - Esri Community
the comments there may be of use in the interim
Hi geodoozer,
I found this solution, because I had the same issue. you are able to add this yourself.
Here's how:
under Project, click Options, then units, select distance units, in the table on the bottom row select the unit you would like to be available for the scale bar; nautical miles.
after you say ok in this window you will be able to go back and choose this unit in the scale bar menu.
As @CTalbot showed this is available, you just have to add the units to the project. Closing as already offered.
