Consistency in Output Field and Location
1899
09-11-2012 12:46 PM
Status: Implemented
JenniferBorlick
Some of the Geoprocessing tools require the user to input the output location and the file name separately. Some of the geoprocessing tools have them all in one field. It would be much more user friendly if they were all one or the other.
2 Comments
DrewFlater
Two of the most commonly used tools that used the output location + name pattern for parameters are being replaced in ArcGIS Pro 3.0. Feature Class To Feature Class is being replaced by an improved Export Features tool, and Table To Table is being replaced by an improved Export Table tool.
KoryKramer
As Drew stated, the most common uses of this were in exporting feature classes and tables. Here are the tools he mentioned:
https://pro.arcgis.com/en/pro-app/latest/tool-reference/conversion/export-features.htm
https://pro.arcgis.com/en/pro-app/latest/tool-reference/conversion/export-table.htm
See Ideas in ArcGIS Pro 3.0  to see this and all of the other ideas you can look forward to when you upgrade.
Also be sure to check out the What's New documentation: https://pro.arcgis.com/en/pro-app/latest/get-started/whats-new-in-arcgis-pro.htm
