Check / Repair Geometry tool should be able to run against versioned Enterprise GDB's
3023
01-12-2022 05:18 PM
Status: Open
Thomas_Bennett
We should be able to run these tools against a versioned EGDB to handle geometry issues.  It could run the tools against the DEFAULT version, and it would even be OK to run it against the EGDB when it doesn't have any active user versions.
Current workaround is to un-version the database - run the REPAIR GEOMETRY - then re-version everything.
Other workaround is to export everything to a File GDB and then import/load the data back into the EGDB  which can be convoluted, time consuming, and introduce editor tracking and ObjectID concerns.
3 Comments
PaulHoefflerGISS
We support this idea. This is a major limitation for basic functionality that can't be applied to "enterprise" geodatabases.
AndreaB_
Strongly support! I'm about to do one of your workarounds for this next week. 🙁
CaitlanRyan
This idea was proposed over 4 years ago now, is there any status update?
@esri?
Thank you!
