Change "Split Policy" for all or many Domains at Once
1781
8
03-27-2024 01:15 PM
Status: Open
EricPetersen
ESRI should implement a feature that allows the user to change the Split Policy for all of the domains in a feature class or geodatabase at the same time. Most often when splitting a shape feature, the original information from all or most fields is desired to be retained in both of the new records. Changing the split domain for all domains to "Duplicate" from "Default" one by one is cumbersome and time consuming. An ArcPy solution is shown in another thread, however this would be a useful feature to implement in the GUI to streamline workflows for many users.
8 Comments
SSWoodward
Thanks for the Idea @EricPetersen .  I can see how this would be a useful feature in the UI now that we've enabled multiselect in the domains view.
For those finding themselves here while this idea develops, the following python command can be used to achieve this.
import arcpy
gdb = <path to your geodatabase>
split = "DEFAULT" # (DEFAULT/DUPLICATE/GEOMETRY_RATIO* - Range Domains Only ))
domains = arcpy.da.ListDomains(gdb)
for domain in domains:
    arcpy.management.AlterDomain(
        in_workspace=gdb,
        domain_name=domain.name,
        split_policy=split,
For more information on the Alter Domain GP tool check out the documentation below.
Alter Domain Geoprocessing Tool
SGTomlins
Good Day @SSWoodward ,
I presume that I still need to remove any locks on the EGDB before running the script?
Thank you
@SGTomlins
SSWoodward
In general, schema changes do require an exclusive lock.
Trying to change the split policy of a domain while another user has the domains view open, for example, will  raise
ERROR 160284: Cannot acquire a schema lock because of an existing lock.
SGTomlins
@SSWoodward I employed your code... worked like a champ...
import
arcpy
import os
from datetime import datetime
# Parameters
server = r"udog"
database = "gis_prod"
username = "sde"
password = "MPblahblahblah" Add the password after creating the script
log_file_path = r"c:\temp\SplitChangePolicy5_Log.txt"
split_policy = "DUPLICATE" # Desired split policy
# Function to write logs
def write_log(message):
try:
with open(log_file_path, "a") as log_file:
timestamp = datetime.now().strftime("%Y-%m-%d %H:%M:%S")
log_file.write(f"{timestamp} - {message}\n")
print(message)
except Exception as e:
print(f"Error writing to log file: {e}")
# Initialize the log file
def initialize_log():
try:
if os.path.exists(log_file_path):
os.remove(log_file_path)
write_log("Log file initialized.")
print(f"Error initializing log file: {e}")
exit(1)
# Function to create a workspace connection
def create_workspace():
try:
connection_file = os.path.join(r"c:\temp", "gis_prod_util_connection5.sde")
if os.path.exists(connection_file):
os.remove(connection_file)
arcpy.CreateDatabaseConnection_management(
out_folder_path=r"c:\temp",
out_name="gis_prod_util_connection5.sde",
database_platform="SQL_SERVER",
instance=server,
account_authentication="DATABASE_AUTH",
username=username,
password=password,
save_user_pass="SAVE_USERNAME",
database=database
write_log(f"Workspace connection created: {connection_file}")
return connection_file
error_message = f"Error creating workspace connection: {e}"
write_log(error_message)
write_log(arcpy.GetMessages(2))
exit(1)
# Function to update domains and check compatibility
def update_domains_and_check_geometry(gdb):
try:
if not domains:
write_log("No domains found in the geodatabase.")
return
total_domains = len(domains)
write_log(f"Total domains in geodatabase: {total_domains}")
try:
# Log domain details
write_log(f"Processing domain: {domain.name}")
# Get feature classes using the domain
associated_classes = get_feature_classes_using_domain(gdb, domain.name)
for fc in associated_classes:
# Check geometry type compatibility
desc = arcpy.Describe(fc)
geometry_type = desc.shapeType
if domain.split_policy == "GEOMETRY_RATIO" and geometry_type == "Point":
write_log(
f"Warning: Domain '{domain.name}' with GEOMETRY_RATIO is applied to point feature class '{fc}', which is not supported.")
else:
write_log(
f"Domain '{domain.name}' is compatible with feature class '{fc}' of type '{geometry_type}'.")
# Update the split policy for the domain
in_workspace=gdb,
split_policy=split_policy
write_log(f"Domain '{domain.name}' updated with split policy '{split_policy}'.")
write_log(f"Error updating domain '{domain.name}': {e}")
write_log(f"Error listing or updating domains: {e}")
# Function to get feature classes using a specific domain
def get_feature_classes_using_domain(gdb, domain_name):
feature_classes = []
arcpy.env.workspace = gdb
for fc in arcpy.ListFeatureClasses():
fields = arcpy.ListFields(fc)
for field in fields:
if field.domain == domain_name:
feature_classes.append(fc)
break
return feature_classes
# Main script execution
def main():
start_time = datetime.now()
initialize_log()
write_log(f"Script started at {start_time.strftime('%Y-%m-%d %H:%M:%S')}.")
try:
# Create workspace connection
workspace = create_workspace()
arcpy.env.workspace = workspace
arcpy.env.overwriteOutput = True
# Update domains and check compatibility with geometry types
update_domains_and_check_geometry(workspace)
end_time = datetime.now()
elapsed_time = (end_time - start_time).total_seconds()
hours, remainder = divmod(elapsed_time, 3600)
minutes, seconds = divmod(remainder, 60)
write_log(f"Script completed successfully at {end_time.strftime('%Y-%m-%d %H:%M:%S')}.")
write_log(f"Elapsed time: {int(hours)} hours, {int(minutes)} minutes, {seconds:.2f} seconds.")
print(f"Script completed successfully in {int(hours)} hours, {int(minutes)} minutes, {seconds:.2f} seconds.")
write_log(f"An error occurred: {e}")
if __name__ == "__main__":
main()
SGTomlins
@SSWoodward   I employed your code snippet and it worked like a champ...
import arcpy
import os
# Parameters
server = r"un-az"
username = "sde"
password = "MjunkjunkJunk" # Add the password after creating the script
try:
print(message)
try:
exit(1)
try:
instance=server,
username=username,
password=password,
database=database
exit(1)
try:
if not domains:
return
try:
write_log(
else:
write_log(
in_workspace=gdb,
break
def main():
initialize_log()
try:
main()
SSWoodward
Nice!  Love to hear it, @SGTomlins. Thanks for letting me know.
JeffG
Very New on the admin side but believe I need to change the split policy because once I try to split a feature, I lose the whole feature.
This is a map that has been created and is in current production so my fear try to modify this policy and screw up the whole map causing more issues to deal with.  Can I change the split policy to duplicate without fear of messing up the whole domain?
Any help would be good help.
Thanks
SSWoodward
Can you clarify what you mean by "I lose the whole feature." ?
A domains' split & merge policies determine what attribute value should be written to the resulting feature(s) during each respective operation.  Having no features present after a split operation would be unexpected. Is that what is occurring?
