BIM Import log file
615
02-02-2024 08:47 AM
Status: Open
Jeff_VanEtten
We are trying to import some BIM (Revit and IFC) data into ArcGIS Pro 3.1.4.  The files are loading successfully, however some elements are not being imported.  As there is little or no feedback on these elements that have failed to import, it would be useful to have a log file that is generated to feedback to the user the failed to import elements and reason why (e.g. unsupported feature type, etc).  Without this, it is almost impossible to tell in very complex models if everything is being imported correctly.  Plus if we are wanting to help improve the process of importing BIM data into GIS, we need to let our modellers know what is not working!
The images views below are 1) of the view inside Revit and 2) the view inside ArcGIS Pro.
If useful, I can share the Revit file.
Tags (4)
2 Comments
CiciXiao
Hi Jeff, could you share what Revit Category do those features belong to? Yes if you could share the Revit file, that will be very helpful.
I strongly recommend you to upgrade to the latest ArcGIS Pro version 3.3. That might fix the issue
Cici | Product Engineer CAD/BIM Team
DA_BIM-GIS
@Jeff_VanEtten
Those are extrude simple geometry elements. Pro 3.1 would not read them, but that has been fixed on Pro 3.2
David
