Applying or changing texture to Revit in ArcGIS Pro
2286
09-30-2018 08:47 PM
Status: Closed
BennyYang
Posting this suggestion on behalf of my Defense Customer. Due to their working environment, there is very limited internet access.
Currently, ArcGIS Pro supports Revit data for direct reading, 3D geo-referencing and publishing. However,  it would be definitely useful to allow GIS users to apply or make changes to the Revit model texture directly in ArcGIS Pro.
4 Comments
ZhiyouSha
There are the same needs in China.
KoryKramer
Is the request to simply change the color/texture of the Revit model in ArcGIS Pro (visualization), or to make a material (e.g. Revit material like Wood, Metal, etc.) type change?
Note that Materials is on the ArcGIS Pro Roadmap - September 2018‌ for a future release.
We're interested in understanding the specific requirements so that we can work with the dev team.
Thanks!
MichaelDavidsonPM
Hi @BennyYang,
You can add material libraries to a default folder location and use ArcGIS Pro to read them. You can additionally navigate to Options -> BIM and specify an alternative folder location with the texture images that you prefer to use.
Also, note that when using geoprocessing tools such as BIM File to Geodatabase:
If the BIM file contains textures, the multipatch feature class will maintain those textures
Thanks for posting, and please let us know if the collective features indicated above address your Idea.
MichaelDavidsonPM
Status changed to: Closed
Hi @BennyYang, thanks again for posting the Idea on applying and making changes to textures when working with Revit models in ArcGIS Pro. As follow-up to the features listed in the post from 06-19-2025, we are marking this as Closed.
