Ability to drag and drop from the Catalog Pane into the Catalog View
748
01-24-2022 03:24 AM
Status: Under Consideration
David_Brooks
MVP Regular Contributor
The ability to Update Data Sources from the Catalog View UI is great. Both the Item and Workspace options work very well.
However, I would like to be able to drop items from GDBs in the standard Catalog Pane (usually found on the right hand side) into the "New Path" fields when updating item sources in the Catalog View UI. Currently, this doesn't work and you get a black stop symbol.
2 Comments
KoryKramer
@David_Brooks
While it isn't the most streamlined, have you tried Copy Path and then pasting into the New Path parameter?
It doesn't nullify your idea of drag/drop, I just wanted to offer that as an option if it isn't something you're already doing.
TanuHoque
