Your ArcGIS Pro Update (May 2025)
2979
05-13-2025 01:39 PM
CaitlynNorth
We’re Excited to Share the Latest Updates in ArcGIS Pro 3.5 with you!
We understand the importance of having high-quality, reliable tools for your work, and it's a priority for us as well. This release not only introduces new features but also enhances the tools that you already use to make them more efficient and effective. Whether you're streamlining complex workflows, collaborating on ArcGIS Enterprise, or speeding up model building, this release is filled with improvements that you'll want to start using immediately.
Here is a quick look at some of the highlights:
  • Work better together: Save your ArcGIS Pro projects directly to your ArcGIS Enterprise portal, so teammates can access, edit, and save changes—no matter where they're working from.
  • Reduce manual entry: Speed up deed mapping with the new COGO Reader. Just upload a PDF or image and let COGO Reader automatically extract and plot courses for you.
  • Edit with confidence: Customize the appearance of vertices, nodes, and more as you edit with a new command that helps you quickly move through your QA/QC workflows.
  • Build models faster: ModelBuilder now includes semantic search so you can ask everyday questions like "How do I loop through rows?" and get results that match. The new Suggest Tool capability also recommends the next step based on your workflow—saving you time and clicks.
  • Improve metadata quality: Access the same metadata editor used in ArcGIS Online and ArcGIS Enterprise—now built into ArcGIS Pro. Enter essential information using a simplified interface and rely on built-in validation to track your progress.
These are just some of the recent advancements made by the ArcGIS Pro team. Read the blog to discover even more, such as location-based definition queries, symbols as point markers in line charts or scatterplots, and dual scale bars in your layouts.
Check out more here
3 Comments
EmmaMattison
New Explorer
Love the update in this release that allows for a spatial query clause in a definition query. It would be awesome if that spatial query could work for publishing ArcGIS Server Services!
AyanPalit
@EmmaMattison Thanks for the note.
Interesting ask on spatial clause support when publishing services. Curious on the use cases and how you accomplish this today.
AKRRMapGuy
@EmmaMattison I second that! I would love to be able to query out data that does not intersect another layer at the service level.
For example, we have permit areas inside of 'Land Reserves' and I don't want to show anything to users from that layer that does not intersect with the Land Reserves. I know other filters can do it, but the spatial relationship would be the fastest and cleanest way.
It's definitely not something I would demand from ESRI, but it would be really really nice.
Contributors
