Riverside County ArcGIS Pro Search Tool Add-In
1982
09-20-2022 04:12 PM
RichardFairhurst
5 2 1,982
August 14, 2025 - The ArcGIS Pro Search Tool has been updated to work in ArcGIS Pro 3.2.
I am releasing the 1.1.1 version of an ArcGIS Pro Search Tool for Riverside County that in this release includes eight (8) of the Search options available in the ArcMap version posted in my Blog here.
The Searches include Search by:
  • Street Intersection
  • APN (Assessors Parcel Number)
  • PLUS Case (Planning and Land Use System)
  • Assessors Subdivision Name/Number or Assessors Recorders Type Book/Page
  • Survey Map Subdivision Name/Number or Survey Map Recorders Type Book/Page.
  • Township, Range and Section(s)  (Released - 9/28/2022)
Before installing the Add-In, if you have installed any previous version of the Add-In you need to uninstall the prior version first.
Open ArcGIS Pro and open the Project Settings page by doing one of the following:.
Before opening an ArcGIS Pro project click the Setting button in the lower left-hand corner of the screen:  RichardFairhurst_0-1664385580959.png
After opening and ArcGIS Pro project click the Project tab in the upper left-hand corner of the screen:  RichardFairhurst_1-1664385621081.png
Click the Add-In Manager menu item on the left hand side of the Project Setting page
Click on the RivCoSearchForms Add-In in the list of My Add-Ins
You can verify the version is out of date by reviewing the Date and Version information prior to removing the Add-In
Click on the Delete this Add-In button at the bottom right-hand corner of the screen
The Add-In will still appear in the list of My Add-Ins until you close ArcGIS Pro, but it will say it is Deleted:
After removing the Add-In you must close ArcGIS Pro before you install the new Add-In..
To Install the Add-In download the attached RivCoSearchForms.zip file.  Extract and double-click the RivCoSearchForms.esriAddIInX file.  Press the Install Add-In button on the Esri ArcGIS Add-In Installation Utility dialog.  The press the OK button on the Installation succeeded notification Esri ArcGIS Add-In Installation Utility dialog.
Open ArcGIS Pro and open or start a project or you can use the "Start without a template" option.   An Add-In tab will have been added to your project, which you can use to choose the Search Option you want and press the cat face Search button to open the search dialog.
Open or create a Map or 2D Layout in your project prior to using the cat face search tool.
The search tool will verify that your current active map has the layers the tool requires.  If necessary it will add them to the map provided that the tool is able to create a Database Connection to the SQL Server Database Platform using the RCIT-19GISP01 Instance with Operating System authentication using the GDB_PUB Database.
If you cannot directly connect to Riverside County's GIS data server, but have obtained copies of the appropriate Riverside County Feature Classes in your own geodatabase, you can create the necessary layers by adding the following feature classes to your map and renaming the layer it creates with the layer name shown below:
Feature Class Name - Layer Name
CENTERLINE_INTERSECTIONS - Search Intersections
ADDRESS_POINTS - Search Address Points
PARCELS_CONDOS_CREST_VW (or PARCELS_CREST) - Search Parcels
PLUS_ACTIVITIES_MODIFIED (or PLUS_ACTIVITIES) - Search PLUS Cases
RECORDED_MAPS - Search Survey Maps
ROADBOOK_PAGE_INDEX - Search Road Book Page
SECTIONS - Search Sections
ADDING THE SEARCH TOOL ADD-IN BUTTON AND COMBOBOX TO THE QUICK ACCESS TOOLBAR
For easy access to the tool you can add the Search button and combobox for search options to the Quick Access toolbar as a onetime set up.  Do the following:
Dropdown the Customize Quick Access Toolbar menu as shown and press the Customize the Ribbon option.
In the Options dialog scroll to the bottom of the list on the left side of the dialog and press the Quick Access Toolbar option.
In the Customize the Ribbon combobox in the Options dialog choose All Commands
Type search into the textbox dropdown and choose the Open Search Choice button and press the Add button and then choose the Search (Extended Caption) combobox and press the Add button.  The icon for the Open Search Choice button has changed from a Cat to R2D2.
The list of tools should look like the items shown below and press the OK button
The Quick Access Toolbar should now look like this.
You can also access the Search Tools through the Add-in tab:
Choose the search you want in the dropdown and press the R2D2 button to launch the search dialog.
If you have any questions, please post them here.  This Blog will be updated as I release expanded or updated versions of the Search Tools and the date time of each revision publication will be added to the list at the bottom of this blog post.
Originally published version 1.0 by Richard Fairhurst on September 20, 2022 at 4:07 PM PST.
Updated the Add-In zip file to make improvements to the validations performed in response to user data entry in the APN Search dialog.  Published by Richard Fairhurst on September 21, 2022 at 9:30 AM PST.
Updated the Add-In zip file to version 1.1 to add a new Township, Range and Section(s) Search dialog option.  Published by Richard Fairhurst on September 28, 2022 at 10:38 AM PST.
Updated the Add-In zip file to version 1.1.1 to change label placement properties of the Standard Label Engine to label each feature part when the Search layers are added to the map.  Published by Richard Fairhurst on October 2, 2022 at 4:45 PM PST.
Replaced ArcGIS Pro Search Tool so that it now is for ArcGIS Pro version 3.2 and higher.  Changed Open Search Choices button icon from a Cat to R2D2.  Published by Richard Fairhurst on August 14, 2025 at 9:00 AM PST.
2 Comments
JesseCloutier
Esri Community Manager
Thanks for sharing this detailed walkthrough with the rest of Esri Community, @RichardFairhurst!
RichardFairhurst
On September 28, 2022, I released a new version of  my Add-In that added an option to search for Township Range and Section(s) within Riverside County.  This is how the tool looks:
If you only want to find a single Section you can use the keyboard to do all the steps.
Type the number of the Township you want (Example 2) and press the Tab key
Type the number of the Range you want (Example 6) and press the Tab key.
Optionally you can toggle the slider button to change the W and E Direction of the Range by pressing the Enter or Space key and press the Tab key
The grid will change at each of the above steps and if any Sections do not fall within Riverside County they will be disabled.
Type the number of the Section you want (Example 28) and press the tab key - the number you typed will blank out and the appropriate Section toggle button within the central Township and Range of the grid will be selected (if it is valid in Riverside County).
The Launch button will now have focus and you can press the Enter key or Space key on your keyboard to activate the Launch button and zoom to the Section.
If you only want to use the mouse you can Left Click on the Township and Range combobox dropdowns and the Slider Button for W and E to chose the Township and Range you want.
To select one or more Sections in the grid with the mouse there are several options:
You can do a single Left Click on one of the Section toggle buttons to select it and deselect all other selected toggle buttons.
If you do a single Left Click while holding the Shift Key on the Keyboard you can select additional Section toggle buttons individually without affecting any selected toggle buttons that you didn't click.
If you do a single Left Click while holding the Control Key on the Keyboard you can invert the selection of each Section toggle button individually (if it is unselected, it becomes selected or if it is selected, it becomes unselected).  This does not affect any selected toggle buttons you didn't click.
You can Left Click, Drag and Release the Left mouse button to select a rectangular group of Section toggle buttons and deselect any selected toggle buttons that are outside of the rectangle.  When dragging in the mode the rectangle appears like this:
You can Left Click, Drag and Release the Left mouse button while holding the Shift Key on the Keyboard to select all of the Section toggle buttons that fall within the rectangle you drew.  The Section toggle buttons that were selected that are outside of the rectangle will be unaffected.   When dragging in this mode the rectangle appears like this:
You can Left Click, Drag and Release the Left mouse button while holding the Control Key on the Keyboard to invert the selection of Section toggle buttons within the rectangle you drew.  The Section toggle buttons that were selected that are outside of the rectangle will be unaffected.   When dragging in this mode the rectangle appears like this:
Contributors
