Parcel Fabric 2torial - Strata Parcels (Floor Aware)
4262
11
02-27-2023 02:05 PM
JasonCamerano
Hello Parcel Editors,
Here's a 2torial (a two minute tutorial) on a new feature in ArcGIS Pro 3.1; Strata Parcels.  This new functionality allows you to enable floor awareness for any parcel type.  Simply adding the new field FloorOrder (type LONG) to both a polygon and line feature class of a parcel type will enable this new functionality.  Watch this video to see how to make your vertical parcel data more accessible both in 2D and in 3D.
For more information on all the features seen in this video please check out the following links:
JasonCamerano
Hey @LearnThenShare_JC
The Floor Order field is simply a LONG field nothing else special.  It does not need to be set up as a required field and it can accept NULL values.
The only behaviors that happen when the Floor Order field is created on both lines and polygons is that when running the Duplicate Parcels tool and using the Floor Order field as the Update Field, the lines will be duplicated for each iteration.  The behavior for Duplicate Parcels when using any other field the lines will not be duplicated, only the polygon.
So to answer your questions individually:
1. The field can be empty (null) and back-filled
2. The 3D visualization is up to you how NULL Floor Order values are presented.  You can set up the extrusion method however you please.
3. Long does not have to have a DEFAULT value.  It can be null.  You can set up a default value if you like meaning that all parcel polys and/or lines can always default to 0.  But that is not required.
4.  We cover strata parcels in this MeetUp briefly:  https://community.esri.com/t5/arcgis-parcel-fabric-videos/meetup-introduction-to-record-driven-workf...
You can also find more info here:  https://pro.arcgis.com/en/pro-app/latest/help/data/parcel-editing/createstrataparcels.htm
LearnThenShare_JC
@JasonCamerano  Hi Jason, You absolutely crushed this with your beautifully articulated answers!  Thank you!!!
John Codd
