Good day Parcel Aficionados,
With the release of ArcGIS Pro 3.5, the parcel fabric team has introduced the COGO Reader Tool. COGO Reader is a new tool designed to assist editors that enter metes and bounds to describe land boundaries.
Here is a short video of Jason Camerano demonstrating the advantages this tool can provide when entering deeds.
https://link.esri.com/ParcelFabric/COGOReader
Enjoy
Dan Stone
Hey Dan, I'm not sure if I am missing something, but I can't for the life of me get the parcel courses | Template to populate. We don't manage parcels but regularly digitize easements and zoning cases, and this tool would be great to incorporate into our workflow.
Disregard. I found the missing step.
Hello, I am also having issues with the Template portion of this tool. Could you tell me what you did to fix it? Thanks.
@LukeRipple Can you please confirm:
I had the same problem, but ChatGPT helped me. I had to go to the catalog pane, right-click on the parcel fabric -> Manage -> Add Parcel Type. This creates a parcel line layer inside the fabric that can be used as a parcel course layer in the COGO reader.
Hello EMCAdministrator, I just tried this and it worked! Now when I open the COGO Reader tool, the connection lines template and the parcel lines template sections are populated. Thank you for suggesting this!
Just for knowledge, what was the missing step?
We have been testing it as we prepare for the transition to Pro. Is the capability of handling non-tangent curves in the works? This seems to be the most consistent error we've encountered. Being able to send it to traverse and then modify is helpful at least.
@HeatherHanson COGO Reader does support non-tangent curves. But in some states/descriptions are written differently and COGO Reader fails to process them.
The best thing you can do is contact technical support and provide a few examples of deeds with non-tangent curves that fail to process. If this occurs a lot, we can consider adding it to one of the 3.5 patches, once fixed.
