Have you seen COGO Reader?
4371
28
06-27-2025 08:19 AM
Labels (2)
DanielStone
Good day Parcel Aficionados,
With the release of ArcGIS Pro 3.5, the parcel fabric team has introduced the COGO Reader Tool.   COGO Reader is a new tool designed to assist editors that enter metes and bounds to describe land boundaries.
Here is a short video of Jason Camerano demonstrating the advantages this tool can provide when entering deeds.
https://link.esri.com/ParcelFabric/COGOReader
Enjoy
Dan Stone
ArizonaGIS2
Hey Dan, I'm not sure if I am missing something, but I can't for the life of me get the parcel courses | Template to populate. We don't manage parcels but regularly digitize easements and zoning cases, and this tool would be great to incorporate into our workflow.
ArizonaGIS2
Disregard. I found the missing step.
LukeRipple
Hello, I am also having issues with the Template portion of this tool. Could you tell me what you did to fix it? Thanks.
AmirBar-Maor
@LukeRipple Can you please confirm:
  1. You are using the parcel fabric
  2. You can see the feature templates visible in the Create Features pane?
EMCAdministrator
I had the same problem, but ChatGPT helped me. I had to go to the catalog pane, right-click on the parcel fabric -> Manage -> Add Parcel Type. This creates a parcel line layer inside the fabric that can be used as a parcel course layer in the COGO reader.
LukeRipple
Hello EMCAdministrator, I just tried this and it worked! Now when I open the COGO Reader tool, the connection lines template and the parcel lines template sections are populated. Thank you for suggesting this!
Fabian_Shenk
Just for knowledge, what was the missing step?
HeatherHanson
We have been testing it as we prepare for the transition to Pro.  Is the capability of handling non-tangent curves in the works?  This seems to be the most consistent error we've encountered.  Being able to send it to traverse and then modify is helpful at least.
AmirBar-Maor
@HeatherHanson  COGO Reader does support non-tangent curves. But in some states/descriptions are written differently and COGO Reader fails to process them.
The best thing you can do is contact technical support and provide a few examples of deeds with non-tangent curves that fail to process. If this occurs a lot, we can consider adding it to one of the 3.5 patches, once fixed.
