In the Pro Parcel Fabric when you traverse an entire subdivision what do you do with the historic/parent parcel? Before doing the traverse do you run the Set Historic tool on the parent parcel or do you run the Delete Parcel tool on the parent parcel? When these tools run do the lines also get retired/deleted or do you have to select the lines separate. I've been having trouble with the workflow and I can't tell if it is my imported data that is giving me strange results or if I'm not using the correct tools. Thanks for the help.
