Shrink to seed made a polygon
853
12-15-2022 02:25 AM
VassilisTrigkas1974
Hi!
When I'm trying to run shrink to seed it creates a polygon inside seed "hole"
any idea why happen this?
AmirBar-Maor
@VassilisTrigkas1974
I suspect it is your seed symbology. The Seed is actually a small round polygon.
You can symbolize it as you please.
If you click on the Seed symbol
you can modify the symbology
to make sure this is a symbology issue you can always add the parcel fabric to a new map, get the default symbology and see how it looks.
Other thoughts: could also be 2 overlapping parcels from different types, a small round parcel that looks like a seed.
Please confirm if this is indeed a symbology issue
AmirBar-Maor
VassilisTrigkas1974
I think you are right!!!! 😁
VassilisTrigkas1974
I checked it again and finally, the color comes from the parcel, not from the seed!
As you can see from the image.
AmirBar-Maor
Thanks for confirming. If you want to symbolize based on a field (Category) as well as the Seed, you might need a few lines in Arcade.
I think something like this would work:
If ($feature.IsSeed == 1) return 'Seed';
return $feature.<your field name>;
 You enter it in the symbology pane:
