Publish the parcel fabric as a feature service missing properties
1737
01-11-2024 01:59 PM
DiegoLlamasOlivares
Hello,
I am trying to publish a parcel fabric, I copied data using gisadmin user to the enterprise geodatabase, i selected branch versioning and followed this instructions.
https://pro.arcgis.com/en/pro-app/latest/help/data/parcel-editing/workflow-publishpf.htm
Validation and include topology layer options are missing.
all my layers and tables are versioned.
This is how are arranged
these are the layers how i am publishing them. my user has assigned a parcel fabric license, I have a ArcGIs Enterprise 11.1, ArcGIS Pro 3.1.4, SQL Server 2019
What can be happening? I have done several services before and I was able to do it but now, those options for publishing does not appear. Any Idea
Regards,
Diego
ChristineLeslie
Hi Deigo
I can see from your screenshots that Version Management is missing under Capabilities and Include topology layer is missing under Feature Properties.
All I can think of is - did you set the versioning type to Branch before you added the parcel fabric to the map?
Christine
DiegoLlamasOlivares
Hello, Yes, i did branch version before add PF to the map. I did it several times
Diego
KenGalliher1
The best thing to do at this point is to run the analyzer. It will of course tell you that Branch Versioning is not set, but it should give clues as to why.
Some things to check when the Branch Versioning option is missing:
1. Make sure the fabric feature dataset was registered as versioned.
2. Is the geodatabase connection file set to Branch?
  • Right click the .sde file and choose Geodatabase Connection Properties
  • There should be an option for Branch versioning
  • If this was the issue, check the option on and re-add your fabric to the map
3. The Validation or other layers and tables were not registered as versioned.
  • Perhaps the parcel fabric is registered correctly but something else isn't.
  • This could be the 3 validation layers and its associated table.
  • Some other supporting layer that is outside of the feature dataset.
Run the analyzer and let us know what it reports.  Thanks!
DiegoLlamasOlivares
Hello Ken,
Yes it gives me this version error for all my layers, besides dataset i have 3 objects layers and one table, and all of them are set to branch version.
I have un version and version all the layers and dataset several times and i continue with the error.
DIego
KenGalliher1
Ah, OK. According to the error, the feature classes are registered as versioned but the connection file is not set to Branch.
00264: Branch versioned dataset, <value>, is not supported from a versioned workspace when the servi...
  • There should be an option for Branch versioning. Select Branch
  • Re-add the fabric to the map
