Pro 2.9.x and earlier: Turning "Show Only Active" on/off makes the Create Features templates go crazy
572
08-03-2022 08:55 AM
jcarlson
MVP Esteemed Contributor
Maybe this is more of a Pro question generally, but I'm wondering if anyone else has seen this. Here's what happens when I toggle Show Only Active.
This causes the UI to hang indefinitely. If the Create Features pane is hidden, this doesn't happen. I can only get it to stop wigging out if I hide or close the pane.
- Josh Carlson
Kendall County GIS
anna_garrett
Occasional Contributor III
This also happens to me with 3.0
AmyAndis
Hi Anna and Josh,
Thank you for reporting this behavior and I can reproduce this at 2.9 and 3.0.
We will take a look and try to get it fixed.
Thank you,
Amy
