Loading and saving txt files in ArcGIS Pro's COGO
1670
08-27-2018 07:41 AM
PRuss
Can loading and saving txt files be done in ArcGIS Pro's COGO traverse?
Searched around and have not found any info on it.
Tags (3)
Robert_LeClair
Esri Esteemed Contributor
From what I've been able to research, it would seem AGP 2.3.x will support the functionality of the Traverse tool found in ArcMap.  The save to text file workflow in ArcMap will be different in AGP - not sure how as I work in Education Services not AGP Development.  Hope this helps!
AmirBar-Maor
Tim Hodson‌ has written an Add-In to import traverse text files.
We plan to add support for importing-exporting traverse files for Pro 2.5 (end of 2019).
If you only use traverse files as a back up you don't need them:
  1. Every traverse course is a feature (not a sketch), so you can simply press save edits
  2. You can modify a traverse by tracing it in Pro if you find a mistake or want to pick it up from where you have left.
DaleBridgford
Is the ability to import and export traverse files still in the queue for the Pro 2.5 release?
AmirBar-Maor
Yes Dale
If you want to see a demo you can sign app to this event:
What's New ArcGIS Pro 2.5 for Parcels? | Meetup
