Edit operation failed. Message: Unable to complete operation. Details: Unable to perform applyEdits operation. Error: Invalid column value [SUB_YEAR].
1326
5
06-09-2025 08:59 AM
-_Ashley-B-Potter_-
(view in My Videos)
Please see the video attached.
I had this functioning properly last week; however, I am now encountering an error message that I believed we had resolved. Please note that this field is not related to the subyear.
This only occurs if we are outside a record.
AmirBar-Maor
@-_Ashley-B-Potter_-
Do you use Attribute Rules that use the SUB_YEAR field? Perhaps they expect a value that does not exist (e.g. 'NULL').
Technical support can also help here.
-_Ashley-B-Potter_-
@AmirBar-Maor I do have an attribute rule that pertains to a sub-year. I also have another one that is identical to it but a different field that is not prompting any issues.  I will look at it again. @RobertChaney
Attribute Rules:
var sourceTable = FeatureSetByName($datastore, "L1Records", ["TaxYear"], false)
$feature.CreatedByRecord;
var createdBy = $feature.CreatedByRecord
var fabricRec = First (Filter (sourceTable, "GlobalID=@createdBy"))
var fabricRecTaxYear = "No Tax Year found"
if (fabricRec != null){
    var fabricRecTaxYear = fabricRec.TaxYear
return fabricRecTaxYear
var sourceTable = FeatureSetByName($datastore, "L1Records", ["SubYear"], false)
var fabricRecSubYear = "No Sub Year found"
    var fabricRecSubYear = fabricRec.SubYear
return fabricRecSubYear
AmirBar-Maor
I have modified your expression
  1. Account for the situation in which CreatedByRecord is empty = NULL. For example, if someone forgot to create an active record.
  2. Use the IsEmpty method instead of checking for 'null'
  3. Only create a FeatureSet if the CreatedByRecord is not empty
  4. A bit of cleanup
For better performance, you can use the triggering fields to only trigger the rule when the CreatedByRecord field is changed.
Let us know if this helps
var sourceTable = FeatureSetByName($datastore, "ParcelFabric_Records", ["SubYear"], false)
If (!IsEmpty(CreatedBy)){      //if the CreatedByRecord is not empty
    if (!IsEmpty(fabricRec)){ //If the returned record is not empty = record was found
        return fabricRec.SubYear
return "No Sub Year found"
-_Ashley-B-Potter_-
@AmirBar-Maor Thank you. I will give this a shot and update accordingly.
-_Ashley-B-Potter_-
@AmirBar-Maor we had to summit a ticket
