Hey folks, I hope you can help me out.
I have been messing around with the Traverse tool and I have hit a bit of a snag. I have my traverse set up to take the delta as the final parameter for my curve, but my description gave me arc length and chord length. When I try to use the chord override - 119c it still uses dms as units and I end up with 119° 00' 00" when I hit enter.
Here are some screen shots:
Which gives me this when I hit enter:
Before you say "Change the dms to feet.", I tried, it only offers angle units - dd, dms, ra.
I like to use the delta angle for my go to curve parameter, so I need to be able to override it when it isn't given to me in the description. I get the same behavior when I use the arc length override.
I should mention, I am editing a line feature class that has COGO attributes, not a parcel fabric.
Am I missing a setting?
