Geoprocessing Tool: Check the Parcel Fabric
1598
6
03-31-2014 06:32 AM
Status: Implemented
JohnFell
Occasional Contributor III
In a typical production editing environment avoidance of heavy query and loading operations during peak hours is essential for optimal performance. With a large parcel fabric, utilizing the check the parcel fabric command on a production dataset during normal business hours is not the best approach. It would be helpful to be able to schedule the Check the Parcel Fabric command along with other maintenance jobs run on the enterprise geodatabase via a python script. If the Check the Parcel Fabric were formalized into a geoprocessing tool for example, this would facilitate periodic topological integrity checking. The report or log file could be reviewed at a later time and plans made to correct any geometry issues.0EME0000000TlMR
6 Comments
SarahMoussadji
Additionally, if the Check Fabric function were available as a GP tool, you could like select a set of parcels you wanted to check, and the tool would respect your selection (this is how most GP tools work). Right now, the Check Fabric is "all or nothing", making it impossible to just check a subset of new parcels. I would love to see this enhancement added in the future!
Rachael_Low
In addition to the above  suggestion , once the Check Fabric function is completed, it would be beneficial to have the option to choose the error and zoom to that error in the Fabric Errors window instead of using the search tool.
Furthermore, after running the check parcel error tool I get different results, has anyone else come across this issue?
MichaelVolz
Are you not able to run this tool in python and then run it as a Scheduled Task at a designated time during non-business hours?
AmirBar-Maor
This is implemented in Pro using: geodatabase topology, Attribute Rules and LSA (Consistency check). No more alphanumeric reports but real error features.
AmirBar-Maor
In ArcGIS Pro you can run a geoprocessing tool to validate (check) your parcel fabric.
Beyond the rules you can configure to meet your business needs the result are error features that can be inspected visually on the map as well as in the Error Inspector:
AmirBar-Maor
Implemented in ArcGIS Pro
