'Zoom to' layer not working on map viewer
5841
17
03-21-2022 06:16 AM
DaveBrown
I've set up a number of features (simple points and lines) within multiple layers (within group layers) on my ArcGIS Online map. Within Map Viewer, whenever i go to Layer and click on 'Zoom to', I expect the map to zoom in to the small area the features are within (e.g a postcode in London), however the map zooms out to larger than the entire world. When the same is tried on map viewer classic, it works fine.
DaveBrown
That would be very handy thanks. Could you add to the group and provide a step-by-step on how to complete it?
Thank you
RussRoberts
Esri Notable Contributor
Opened the web map in Pro, used model builder to iterate through the layers and use the tool Feature to Graphics.  Publishing up a sample to the group now and you can download the SD file to publish your own copy to the org.
DaveBrown
Thanks Russel, found the files in the folder. Do i need ArcGIS pro to be able to complete these steps? My organisation only purchased the online version of ArcGIS.
neomapper
We're experiencing the same issue with the new map viewer. We select a layer in the search bar, query for a key valve, select one and then get zoomed out to the furthest extent.
DylanT_EsriCanada
It looks like this has been recorded as a known issue now.
WIGS
Hello is there any information of this or possible solution?
neomapper
I don't believe this was fixed.
trandich
Any update here? I am finding the same issue in my Web Experience. It happens when an action is configured from a Search widget, and also when selecting the "Zoom to" icon in the popup. I am zoomed out to the entire world instead of into my polygon. Thanks,
Ted
