WMS can't be adjusted on a WMTS basemap
878
11-05-2013 10:50 PM
ArnauFORNER1
I 'm trying to use a WMTS as a basemap. Its coordinate system is EPSG 3812.
http://www.ngi.be/cartoweb/1.0.0/WMTSCapabilities.xml
Then I want to add a WMS that have the same coordinate system: EPSG 3812, but also accepts 4326 and 4258.
http://ccff02.minfin.fgov.be/cadgisWMS/CP_CadastralParcels/MapServer/WMSServer?SERVICE=WMS&REQUEST=G...
When I try to add it I receive the following message: " can not be added to the map because its coordinate system can't be adjusted to align properly with the basemap."
Can anyone help me?
Thanks in advance
MikeMinami
Esri Notable Contributor
This is a bug. ArcGIS.com was not reading the other supported coordinate systems. I have verified that this works correctly on our development servers as the layer does overlay. We will be releasing a fix in December.
I did notice, however, that the WMTS service appears to return all white images for me, using the TOPO layer. I don't know why...
Mike
