Why does "Enable editing" get stuck on "updating item"?
1456
03-21-2019 03:13 AM
TrevorPhillips
ArcGIS online: Feature Layer (hosted). Why when I try and check (tick) "Enable editing" and click "Save" my section is not accepted the screen gets stuck on "Updating item"Enable EditingUpdating Item
by Anonymous User
Not applicable
Hello!
A few questions -- Does this happen with other feature layers or just this one? Also, are other users also encountering a similar issue?
You can try to clear your browser cache and/or use a different network to see whether or not the problem persists. Hope that helps!
Adam222
Having the same issues ?
Did you end up solving this issue>?
cupofjojo
Having this same issue.
Tried different browsers, cleared browser cache, tried it with different layers - same thing happens.
Any guidance?
BradCollingwood
Has anyone had any luck sorting this problem out?
