Why can't I see $map on arcGIS arcade?
398
7
2 weeks ago
Matgo
Hello! I want to use the $map on my new map but I can't see on the profile variables (look at the picture below).
I have another map that I've use $map on (look at the pic below)
Can someone explain to me why I can't see and use the profile variables $map.
Thank you
CodyPatterson
MVP Regular Contributor
Hey @Matgo
From my testing, I was able to see $map on every layer such as Web Map, Feature Layer and Hosted Feature Service, may have swapped those, but the one I didn't see map on was a Map Image Layer. If you're using a Map Image Layer, you won't be able to access the $map variable as it's a different type of layer and doesn't allow querying the same way that the other layers do! Has this worked with other Map Image Layers?
Cody
CodyPatterson
Hey @Matgo
Cody
Matgo
Hello Cody! You are right, the layers I can't see $map are Map Image Layers, the other one I can see are feature layers! Now I know whats the problem! Thank you 🙂
Matgo
Is there a easy way to transform my Map Image Layers to Feature layers?
CodyPatterson
Hey @Matgo
Glad you were able to find the differences! I wasn't sure myself until I went through each!
In terms of transferring, if this was a layer that was uploaded from Pro, you may need to reupload the layer with the Feature button turned on, something like this here:
If this was uploaded with Pro already, there could be a chance that the Feature layer may exist with the same name, I would check your items on ArcGIS Online and see if one is already there, I've done that many times! In terms of conversion, I don't believe there's a 1-1 way.
Cody
Matgo
Thank you! I'm using arcmap. But if it doesnt work then it's okay. It's not very important the thing I wanna do on arcade. But its good that I know this problem, thank you!
RhettZufelt
MVP Notable Contributor
With ArcMap you can use Catalog to enable feature access in the Service Properties:
R_
Matgo
Oooh nice! Gonna try it later 🙂 Thank you so much! 🙂
