Where is CALCULATE? (not visible in my WebMap)
8221
21
05-17-2017 01:12 PM
ShawnCarson
I know I am missing something obvious so forgive me.
I opened my table (Web Map).
I select some records.
I left click on column name.
I can't see CALCULATE but I do I see Sort Ascending & Sort Descending.
I have a Hosted FeatureLayer
I am the owner of the data
I am also the administrator.
I can edit features using the EDIT button and in Collector.
Where is that CALC button, am I looking in the wrong spot?
I want to do a mass calc. (Bonus Question: Can someone confirm I can select multiple features form the table but I can only select one feature at a time on the map?
Thanks for reading
Shawn
JayantaPoddar
If you are the owner of a hosted feature layer, or an administrator of your organization, you can add, delete, and calculate fields on hosted feature layers.
Work with fields—ArcGIS Online Help | ArcGIS
Think Location
ShawnCarson
Thank you for replying Jayanta. That is why I am puzzled I am the owner and also adminstrator. Can you confirm where this CALCULATE function resides? I may be looking in the wrong spot....
Thanks for helping...
JayantaPoddar
  1. 1. Follow the steps to show a table.
  2. 2. Click the column containing the field whose values you want to calculate.
  3. 3. Click Calculate.
    The Expression Builder dialog box appears.
    Could you provide further details about the hosted feature layer (how you added the hosted feature layer),  with screenshot of the page with attribute table and its options.
Think Location
ShawnCarson
Thanks Jayanta,
"Could you provide further details about the hosted feature layer"
Added a layer from filegoedatabase (or geodatabase) no records, just schema to ArcMap.
In ArcMap logged in with my AGOL login
Did SHARE to hosted featureservice. It was then pushed to the cloud
Works with Collector, etc.
OPTIONS in upper right of table says:
Show Selected records
Clear Selection
Show/Hide Columns
Open table (click on TABLE icon under the featurelayer)
KellyGerrow
Esri Alum
Hi Shawn,
Is this a feature layer view or a primary hosted feature layer? It isn't possible to calculate features in a hosted feature layer view or feature layers with a related tile layer:
If the layer doesn't meet any of these needs, I suggest contacting technical support to look into the specific issue.
-Kelly
ShawnCarson
Kelly,
Thanks for replying and sorry for the late reply.
"Is this a feature layer view or a primary hosted feature layer?"
I believe it qualifies as a "primary". I added a layer from my geodatabase to an mxd and then published it as a HostedFeatureService.
I can edit the features using the EDIT button and in Collector.
Thanks so much for replying...
KellyGerrow
Esri Alum
Can you post a screenshot of the entire Overview tab on the feature layer details page?
ShawnCarson
Sure thing. (Thanks for looking...)
Top Half
Bottom half
KellyGerrow
Esri Alum
Thanks Shawn,
This is quite the puzzle. Can you open the layer with full editing capabilities in the web map? It will be an option that appears when you select open in map viewer.
If you still don't see the calculate button, can you post a screenshot of the field you are trying to calculate?
-Kelly
