WFS polygon/line layers displaying in Map Viewer Classic, but not Map Viewer
1671
03-31-2024 10:25 AM
LisaMerkhoferXerces
I am trying to access an WFS OGC Service that has point, line, and polygon data.  I am able to add polygon and line data to my webmap in Map Viewer Classic, where I am given the notice:
"The layer contains complex features which can include points, lines, and polygons. Choose one type of feature to display from this layer."
I can then chose polygons and lines and add the layer to by map. But when I try to open the same saved map in Map Viewer or ArcGIS Pro, the polygon and line features do not display, but the point features display in both Map Viewer Classic and Map Viewer.
Is there a way I can access the polygon and line features in Map Viewer or ArcGIS Pro, even when I am not given the option to select these feature types when adding a WFS?
RussRoberts
Esri Notable Contributor
Are you able to share the layer and we can look into why it isnt drawing?
SheikhHafiz1
@RussRoberts , @LisaMerkhoferXerces
Was the issue resolved?
If yes, how?
I am having a similar one.
Thank you.
RussRoberts
I wasn't given a repro sample so I couldn't look into it.
