Web Scene - Layer Style Error
1416
05-07-2019 05:36 PM
JeenaS
Hi guys!
Just successfully managed to publish my scene layer and loaded it onto my web scene, but as shown, the layer style doesn't seem to read my attributes correctly. I have a column specifying each building as "Prime" or "Secondary". Could there be a reason why that text is not being detected? Somehow all the features fall under "Other".  I am recreating my multi-patch features meanwhile to re-publish and see if it errs again- meanwhile any advice would be appreciated!
RussRoberts
Esri Notable Contributor
Can you share the scene and layer with me? If you cant share it publicly you can create a group and invite russell_jsapi into it and I can try and determine whats going on in your scene.
JeenaS
I have a doubt if its because there are multiple multi-patch features in single point (because of a one to many join I had done to the dataset earlier). I will clean the data up and recreate it again in ArcScene and give you a shoutout if it shows an error then!
