Web Map Application Question
1079
07-19-2023 12:25 PM
jcarswell
Hello Arc Gis Community,
I have previous experience making story maps, however I am trying to make an interactive map to show off current development projects happening around the city. I have a base map with my municipal boundaries, and I to create a web map, but am running into confusion. I am trying to have an application that shows my base map, but will allow me to add extra information. For instance, I would like to drop pins on my map to highlight key locations. When an individual clicks on the pin, I would like a section to left to pop up showing a photo as well as text information. I have worked with a map similar in the past, however I was not present during the creation process, so I am a little confused. I am thinking it may be a particular widget, however I was struggling to find a correct one. I hope this is helpful, and I can explain more if needed. Thank you so much!
Tags (3)
MiguelParedes
Greetings @jcarswell
It sounds to me that what you need might be provided by one of the new Instant App Templates
I would suggest checking the Create and publish your first app page to get you started.
I hope the above is of assistance.
Miguel
