View Error Log of Arc GIS Online?
2343
07-13-2021 01:44 AM
LukasWürsch
Dear all,
In ArcGIS Enterprise it is possible to see errors which occur on the server with ArcGIS Server Manager. This can be very helpful when debugging failed publishing jobs. Is it also possible to access such error logs on ArcGIS Online?
JayantaPoddar
Please check if this works for you.
You can create Organization Activity Report. Exploring the Organization Activity Log CSV
The User interface could be a bit different from what is shown in the above article.
Think Location
LukasWürsch
Thank you for the quick reply. UI has changed quiet a bit indeed. Are you referring to this?
Unfortunately, it seems I can only generate the report for previous months.
