David, Dan,What version of ArcGIS Server are you running? Was it working before and stopped, like maybe after you upgraded?ThanksMike
I had the same problem today. I found that using the token parameter on my map service URL worked.1. Create token on behalf of the user identity with Identifier set to http://www.arcgis.com 2. Include that token value on the Map Service URL that is being added to an ArcGIS.com map.Example URL with token as a parameter:http://arcgisserver.domain.name/ArcGIS/rest/services/mySecureService/MapServer?token=6xgjHf9MIcnI1u87Mfw4is_h4zk2hg8yniTclu9TpwMWw0e5E_3tPxDAcXsStl6hsE2Jw2T0dn1SbqxLliJzQQ..
Secure ArcGIS Server services are now supported in the map when you add the layer directly to the map. From the map, click Add, then click Layer from the web. Enter the URL to the ArcGIS Server service and click OK. You'll be prompted to enter a username and password. This web map can then be referenced from a template and the user will be prompted to enter the username and password. This is supported with ArcGIS Server 10 sp1 and later.Hope this helps,Mike
