Using open street map as base Map in Arcgis online
2071
09-05-2016 02:46 AM
DIALLOAbdoulaye
Hi every one,
I hope i am in the right place, in fact i was wondering if it is possible to use open  street map as base map in Arcgis online.
I am building a web application using the app builder in Arcgis online and i want to have open street map as base map.
Thank in advance for any help or guidance .
DanPatterson_Retired
sadly, the links to ArcGis Online are a bit hidden
ArcGIS Online Help | ArcGIS
but trying to get 'open streetmap' as a returned result is a bit hit or miss, you either get one, or the other, but not both.  Have you tried it? or just wanting to skip a trial?
This link https://community.esri.com/message/576844?commentID=576844#comment-576844
leads one to this link about rest service World_Street_Map (MapServer)
if that is any help
XanderBakker
Esri Esteemed Contributor
When creating a Web Map in ArcGIS Online you can select the basemap using the "Base Map" button and selecting OpenStreetMap:
See also: Choose basemap—ArcGIS Online Help | ArcGIS
DIALLOAbdoulaye
Hi Xander,
Thank a lot
DIALLOAbdoulaye
Hi Dan,
I ve tried but nothing was returned , but it seems that work by using the methode shared below by Xander.
I will give it a try and confirm to you after .
Thank
