Good morning everyone! I started working on a web map and associated web mapping application this morning to show some demographic data for our County. In the web map I removed all of the sub-layers in each demograpic layer except for the Zip Code, Tract, and Block Group levels. However, once I preview the application in Web Appbuilder (expand the legend to turn on / off any of the demographic sub-layers) there are now approximately 50 sub-layers showing up
. The sub layers range in description from State & County Boundaries to tract, block group, county, state, congressional district, CBSA, place, DMA, etc. I'm a little stumped as none of this is visible at all in the base web map from which the application has been built.
The web map can be found here: http://montezumacounty.maps.arcgis.com/home/item.html?id=01ff589d725b4a48b45367c76b2ccc8b
The application under development can be found here: ArcGIS Web Application
Has anyone ran into a similar issue with Living Atlas layers or specifically the demographic data before? Any work-arounds or solutions out there? Thank you for any and all help as always!
