Is it possible to use <iframe src="www.google.com"></iframe> to show webpage images in an arcgis online popup?
Brandon
https://community.esri.com/community/gis/web-gis/web-appbuilder?sr=search&searchId=506a9f1c-8a7b-40ca-a5f7-812b9df2db1e&searchIndex=1
I was able to add an iFrame to a popup in a JS API Sample in the sandbox so it should be possible in WAB as well:
(a google maps url was used).
I would say no. Here is a list of supported HTML in a pop-up: Supported HTML—ArcGIS Online Help | ArcGIS or you would have to code it using https://community.esri.com/groups/web-app-builder-custom-widgets?sr=search&searchId=37e1a1d7-4b3f-43fc-aecc-03157fa15e84&searchIndex=1
Thanks Robert. I will try this later and will be sure to mark correct after.
This is great. This works just fine. Only for https it seems.
Is you app using https protocol?
I think so. It is a story map. I will double check again but I tried https which worked but I couldn't get http to work.
Signed in members can post, follow updates, and more. New here? Register a free account.
