use building footprints from OSM or ESRI base maps?
2823
01-03-2024 03:20 PM
JayLarsen
Is there a way to use building footprints from OSM or ESRI base maps?
I want to tag my buildings in a map for the real estate dept to use.
Both OSM and ESRI have pretty good building footprints, I just need to "cut" out the ones I'm interested in and put them in layer so I can do a JOIN to my ownership and use data?
David_McRitchie
Hey Jay. The basemaps will only be there for contextual mapping and so would not be features you could easily tag unless you manually made features and labeled these.
I would recommend downloading the underlaying data for building footprints. You can get the footprint data from OSM through here.
Hope that helps!
David
Esri UK -Technical Support Analyst
David_McRitchie
Hope that helps!
David
JayLarsen
Yeah, I saw that.  Even d/l a test *.osm file to hack in QGIS.  I was hoping for an "automatic" way?
Maybe I should just draw them? There could only be 20-30 structures in the end? I'll experiment.
Thanks!
