Update Building Scene Layer popup in ArcGIS Online
436
10-03-2024 08:00 AM
simoxu
by MVP Regular Contributor
I am having some issues when trying to update the popup a category layer.
Here is what I did:
step 1. add a new field to the feature layer associated with the building scene layer in ArcGIS Pro
step 2. configure the popup in the associated feature layer in AGOL Map viewer
step 3. rebuild the scene layer cache using full cache option in AGOL
but when I check the scene, the popup for the related building scene layer in the web scene remain unchanged.
The only way to change the popup is to change the schema in the original data source, config the popup and share the scene again from ArcGIS Pro, this is not ideal for my situation.
Has anyone been through this? any advice or comments are highly appreciated.
Thanks!
